Message 1 of 2
BT WiFi App login details problem
Hi, can anybody help me?
I have BT Wifi enabled on my home broadband and I am able to login from my laptop etc using my BT ID. There seems to be a problem with the app. Even though it accepts my login details, every time I click on BT WiFi I get a message saying unable to login and that my saved details may be incorrect. I have tried changing my password. I have managed to get it to work once by deleting and re-installing the app but I get the same message the next time I try to connect.
If I delete the app, I can login using the BT WiFi landing page.  I have called BT several times but no one has been able to fix it. Any help would be greatly appreciated!
1 REPLY 1
Message 2 of 2
Re: BT WiFi App login details problem
You should try contacting the BTWifi app developers to see if the can help
