Message 1 of 6
BT accounts and IPv6
Hi
I've moved up to my parents house to help look after them, and was looking at the IPv6 configuration, is I want to set up OpenVPN tunnel IPv6 over IPv4
I just wanted to clarify some information.
Is the IPv6 allocated as a /56, from which the hub picks the /64 to use?
If yes - is the /56 linked to the account? or the hub?
Thanks in advance.
Tim
5 REPLIES 5
Message 2 of 6
Re: BT accounts and IPv6
@ravenstar68 wrote:
Hi
Neither, for some bizarre reason its dynamic like your IPv4 address
Thanks in advance.
Tim
Not sure why you are asking if you are tunneling IPv6 over IPv4
Message 3 of 6
You say it's dynamic, yet we've had the same /64 and consequently the same /56 for well over a year.  The IPv4 address changes at least every other week.
The reason I asked is because I want to set up the tunnel so that a device connected to the VPN from a remote location picks up an IPv6 address from the OpenVPN server.  But from what I was reading, the server needs to allocate a separate /64
Message 4 of 6
Well it is in theory, maybe not in practice.
So are you running the OpenVPN server at your end?
Message 5 of 6
I am in the process of setting it up at the moment.
The hub is using a /64 in the format
2a00:xxxx:xxxx:eb00:xxxx:xxxx:xxxx:xxxx
So I'm assuming the /56 would be 2a00:xxxx:xxxx:eb::
Message 6 of 6
I assume so.
You can see the prefix in Advanced settings > IPv6 > status
