Message 1 of 5
FTTP Smart Hub Tips
I've recently moved house and got FTTP (fibre 250) and a smart hub. I was wondering generally what tips and good-to-know things i should do with the SH settings? I see a lot of recommendations to turn off smart set up, so just looking for any other knowledge nuggets like that to help with performance and stability.
If it helps i will use it only over wifi to start with, but in the coming weeks will be utilising the built-in network points around the home to hardwire my PC, games console and TV (i assume these work like powerline adaptors without needing the adaptor).
Thanks in advance!
4 REPLIES 4
Message 2 of 5
Re: FTTP Smart Hub Tips
There are no other tips
They are just long Ethernet patch leads.
Thanks in advance!
Message 3 of 5
Don't use a smart hub.
Message 4 of 5
Any particular recommendations if I purchase my own in the near future?
Message 5 of 5
The Asus RT AX88U seems a popular choice.
