Message 1 of 8
BT broadband upgrade problems
I’ve recently had fibre availability open up in my area, and have been intending on upgrading to either full fibre 300 or 900. However when I select the option (900 or 300) and I go through all the steps it then tells me it’s unavailable after it’s just told me that they are available. I’d love some help. Thanks
Tags (1)
7 REPLIES 7
Message 2 of 8
Re: BT broadband upgrade problems
Enter your phone number and post results. Remember delete numbern
Message 3 of 8
Message 4 of 8
You need to phone the FTTP TEAM 08005874787 who will be able to help you
Message 5 of 8
Thank you 👍
Message 6 of 8
Does that say that I should have access to full fibre 300 and 900?
Message 7 of 8
Yes it does.
Message 8 of 8
Cheers mate
