Message 11 of 12
Re: BT engineer came to fix my phone line but disconnected my Alarm and left!
Thank you just got the message. Do you mind saying the name of the alarm company so I can have a look to see if you can get a connection to plug into the mastersocket instead of using wires to wires they must have some solution or a type or lead. Only thing is if someone did Rob you they could disconnect the line so you would need to cover it somehow to make it more difficult keep lights on when away and the general stuff. I use a company that sounds like a telephone can't say the name they use wifi as backup which is pretty cool
BT Fibre to the premise's customer.
Best Regards
Kev
Message 12 of 12
Sorry I mean 3g as backup
Best Regards
Kev
