Message 1 of 9
BT fibre having issues
Is BT having issues as my BB keeps dropping out every 5 minutes or so, it’s affecting my data rate speed which is 55/10 and dropping it to 41/10 and lower. My Noise margin is also being affected dropping from 12/10 to 6/5 which it shouldn’t be doing.
BT status checker doesn’t tell you anything apart from everything is okay BUT it always tells you that as it never updates, downdetector and another site are saying BT are having issues which I seem to agree with as my BB is dropping and my connections are taking ages to connect when it finally comes back on. Can any Mod be honest and let me know please otherwise I’ll be phoning BT and leaving the company
8 REPLIES 8
Message 2 of 9
Re: BT fibre having issues
@Deucalion
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
Message 3 of 9
Quiet line test was fine, 0 noise whatsoever.
Message 4 of 9
Target noise margin is 6.0 why do you think it shouldn't be dropping to that? If G.INP is activated downstream noise margin will drop to 3.0.
Message 5 of 9
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 6 of 9
On 55/10 the noise margin should be higher than 6. Mine shows 12/10 sometimes 14/12 the only time I get a 6 noise margin is when I’m on the fibre 2 package. Spoke to BT about this ages ago and they said that the high noise margin is fine on the profile I currently have, it only drops the SNR to 6 or lower when I go for a faster profile
Message 7 of 9
Is this what you wanted? 
Message 8 of 9
Message 9 of 9
the dslchecker shows you had a 76/20mb connection on 18/9/20 and with that you would have a noise margin about 6db.  you now seem to have gone back to fibre 1 with 55/10 mb connection speed and as your connection speed is well below attainable you will have a noise margin in excess of 6db probably about 12/10db all of which is normal
have your tried using the test socket to eliminate your internal wiring and master faceplate from causing the drops in internet connection?  have you tried a factory reset of hub to see if that helps?  remember if you do then turn off smart setup when hub reboots
