Message 11 of 16
Re: BT in denial?
If you enter your phone number in the checker https://www.broadbandchecker.btwholesale.com/#/ADSL it will tell you which cabinet you are connected to.
Message 12 of 16
Re: BT in denial?
Thanks. Handy advice to use in future.....
Stats below from cabinet 4, made sure no phone details etc. I may come across as angry, and cant force anyone to get off the facebook page and do this too. but it is so frustrating, as people at higher risk, myself incliuded have to work from home and need realiable speed. I do think the engineers do a great job, as does this service. not helped by dodgy phone calls...
That call came from 00767325470710... be warned anyone with a fault... it isnt BT its more of the thieves.
SL Range A (Clean)
VDSL Range B (Impacted)
8064.4201958.8AvailableAvailable--
8062.1201956AvailableAvailable--
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessFTTP on Demand
33030--Available--
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date WBC SOADSL Availability Date Left in JumperWBC ADSL 2+ADSL MaxWBC Fixed RateFixed Rate
Up to 2--1 to 3.5AvailableAvailable--
Up to 1.5--1 to 2.5AvailableAvailable--
1----AvailableAvailable--
1----Available----
Observed Speeds VDSLMax Observed Downstream SpeedMax Observed Upstream SpeedObserved Date
80
20
2020-05-28
Other Offerings Availability DateVDSL MulticastADSL Multicast
Available
Available
Premise Environment StatusBridge TapVRINTE FacePlateLast Test Date
N
N
N
09-07-2020
Message 13 of 16
Re: BT in denial?
Hi @coreservers,
Thanks for posting. Which exchange are you on?
Cheers
David
Message 14 of 16
Re: BT in denial?
Cogenhoe cabinet 4
Message 15 of 16
Re: BT in denial?
here we go again....
24
ms
DOWNLOAD
5.07
Mbps
UPLOAD
715.95
Mbps
Message 16 of 16
Re: BT in denial?
Hi @coreservers,
Thanks for posting. I'd like to take a closer look at this for you so I've dropped you a private message. Just reply with the details and we'll take it from there.
Cheers
David
