Message 1 of 3
BT smart hub 2 showing as Vodafone
I will preface this with a note, I am moving from BT to talktalk in a couple of weeks, and I'm not sure if maybe thats upset something?
This is a really bizarre situation and I cannot fathom what is going on.
So I have a smarthub 2 and it is doing some weird things. I noticed very slow speeds on some devices (both on wifi and directly connected). Some were fine. On doing a speed test I noticed that the IP was Vodafone not BT. If I try to go to homehub login (192.168.1.254) it times out. If I put in the IP address I get from speetest (90.253.77.150) I get a vofafone router login page!
Whats even weirder is I can simultaneously have one computer on vodafone and one on BT (getting great D/L speed) both directly plugged into the router. And the same for wifi, I can have a laptop connected to the wifi on vodafone and one on BT.
Really done understand what is going on here. I have no contract nor ever had with Vodafone, no vodafone router or anything silly like that.  Just the standard smarthub 2 straight into phone line.
Any help is appreciated
2 REPLIES 2
Message 2 of 3
Re: BT smart hub 2 showing as Vodafone
are you using powerline adapters?  do you know if your neighbours use powerline adapter in an adjoining wall?
odd things like this have happen before  and turned out to be caused by powerline adapters
Message 3 of 3
Hi IMjolly
Yes that was it! I had discounted that as a problem, as the powerline is only coming out of one port and connected to one computer, but it was computers on the other ports that were showing the problem. So somehow what must be happening is the powerline signal is using the router as a bypass. Anyhow, securing the powerline network has sorted the problem. Thanks very much!
