Message 1 of 2
Smart Hub Technical Log
I have a Smart Hub 2 with G.fast which generally performs well. However, when it comes to speed, I have noticed the following entries in the technical log
Data rate:9.105 Mbps / 134.061 Mbps
Maximum data rate:8.832 Mbps / 111.693 Mbps
How can the maximum data rate be less than the actual data rate? Is this a nonsense or am I just not understanding it properly?
1 REPLY 1
Message 2 of 2
Re: Smart Hub Technical Log
The maximum data rate is a projected figure predicated on a particular SNRM figure. It is possible that when your line synced initially there was very little noise and thus a high sync speed. I suspect your noise margin figure is now very low and if you were to resync you would resync at a slower speed.
