Message 1 of 2
BT whole house wifi and USB printer connection
Hi,
I am currently using a usb printer (non-wifi) attached to the back of netgear router and that allows wireless  printing.  I want to setup bt whole house wifi discs by attaching to netgear router after switching it's wifi off.
Will I be able to see the printer or usb disc attached to the usb port of the router on the BT wifi and be able to print wirelessly?
I am not sure if there are any affordable mesh wifi systems with a usb port.
Any ideas will be greatly appreciated as I don't want to change my current laser printer.
Many thanks
1 REPLY 1
Message 2 of 2
Re: BT whole house wifi and USB printer connection
Bumping up!
Any advice would be gratefully received
