Message 1 of 2
BT wi-fi hotspots
hi i am considering paying to use a bt wifi hotspot as my own broadband isn’t set up yet and i need internet  to work from home. I’ve never used a hotspot before can I expect it to work as well as my own broadband would?
1 REPLY 1
Message 2 of 2
Re: BT wi-fi hotspots
Hi @HelenDolly
Welcome to the BT Community and thanks for your post!
A BT Wi-fi hotspot gives you the ability to connect to public hotspots when you're out and about.  I wouldn't say it would work as well as your home broadband as the speeds would differ and the purpose of a hotspot is to give you an internet connection for general surfing.
You can view more info about BT Wi-fi hotspots here --> What is BT Wi-fi and how do I get it?
Cheers,
Robbie
