Message 1 of 4
BT wifi disk
Hi,
Just wondering how to open the Wifi disk as one leg has popped out! can't see any screws!
Tried to fix the leg from outside and the inner hold has gone in!
Any ideas will help.
Thanks!
3 REPLIES 3
Message 2 of 4
Re: BT wifi disk
Hi. On the black discs you don't need to unscrew, if you hold the popped off one in the mirror image position of the one still connected they "simply" press back in. Tim
Message 3 of 4
Re: BT wifi disk
@TimSmedley
That's not the case if, as the OP states, the inner bush has become dislodged which it can do.
@Trevstar
I managed to get mine back in place simply by popping a medium sized screwdriver just inside the hole and manouvering the disc both upside down and turning at random until the bush slid over the shank of the screwdriver.
It's not a quick job by any means so you'll need plenty of patience
Message 4 of 4
Re: BT wifi disk
Any expert in here who knows how to open the black BT wifi disk?
