Message 1 of 5
BT4600
I have a BT4600 phone set and I am trying to use a headset with it with a 3.5mm TRRS jack, but the microphone does not work any suggestions
Tags (3)
4 REPLIES 4
Message 2 of 5
Re: BT4600
If your phone is within warranty give the product helpdesk a call:  0800 145 6789
RIC9380
Message 3 of 5
Re: BT4600
@erics_4600
I think you may find that that type of plug short circuits the microphone input. Try a normal 3.5mm plug instead.
Message 4 of 5
Re: BT4600
try a headset you would use with mobile phone - they  usually are included with the  phone
Message 5 of 5
Re: BT4600
Thanks for the suggestion, but the headset I am trying to use works with my mobile phone and my laptop but not with my BT4600 phones.
