Message 1 of 4
BTWifi or BTWifi-X
Hi, I’m a new customer and apologies if this has been previously covered.
Set up my SmartHub 2 and have this choice to select.
Which one to go for please
Cheers PaddyZulu
3 REPLIES 3
Message 2 of 4
Re: BTWifi or BTWifi-X
Those are both public WiFi hotspots that your hub transmits.
Not sure what you mean by which one to select. When at home you connect to the normal hub WiFi signal rather than the hotspot signal. It will have BT hub in the name
Message 3 of 4
BTWIFI-X is for apple devices when out and about
Message 4 of 4
Agh of course thanks senior moment 🙄
