Message 1 of 3
is a Draytek 2860 faster than a BT infinity 2 router
I recently upgraded to FTTP with a download speed of 500. When I plugged my computer into the router I only get a speed of 230 despite  BT telling me that the speed to the router is running at 500.
When I connected via the wifi I got a speed of about 100.
I was using a Draytek 2860 router with my old connection. Would this be any faster than the BT router?
thanks
2 REPLIES 2
Message 2 of 3
Re: is a Draytek 2860 faster than a BT infinity 2 router
Only one way to find out. Plug it in and try it.
Message 3 of 3
The Vigor 2860 firewall is limited to 300 Mb/s due to its older chipset so unlikely to be faster than the SH2.  You can connect your PC directly to the ONT and create a PPPoE connection to rule out any speed issue with the SH2.
____________________________________________
BT FTTP 500/75 + pfSense + 4 x UniFi Wifi 6 Pro
