Message 1 of 14
Banded profile
Good Afternoon,
Is there anyway to get my connection put in a banded profile by the DLM? I've heard resetting the router a few times would do this so how many times would I need to reset my router in order to activate this and put my internet line in a banded profile?
Thanks!
13 REPLIES 13
Message 2 of 14
Re: Banded profile
Say, 8-10 times within an hour. If it doesn't work first time repeat until it does.
Now the main question. Why on earth would you want to be on a banded profile?
Message 3 of 14
Re: Banded profile
The connection the DLM has put me on is awful for online gaming. Despite have a ping of 6ms, perfect speeds and less than 0.7 jitter on my line, the DLM keeps putting me on some awful frequency and online gaming is unplayable. When I’m banded it’s much easier to play
Message 4 of 14
Re: Banded profile
OK, just wondered. Good luck.
Message 5 of 14
Re: Banded profile
Thanks! Do you know how I’d be able to tell if I’m in a banded connection?
Message 6 of 14
Re: Banded profile
It will show in the hub connection stats.
HH5 troubleshooting/helpdesk.
HH6 advanced settings/technical log/information.
Message 7 of 14
Re: Banded profile
@pippincp
(sorry to butt in)
What wordage am I looking for in the technical log/information? (HH6)
thanks.
Message 8 of 14
Re: Banded profile
there is no wording which specifically will say banded profile in stats
https://community.plus.net/t5/Library/FTTC-DLM-What-it-is-How-it-works/ba-p/1322799
Message 9 of 14
Re: Banded profile
Just been stuck on the same for 42 days now :(.  Worth trying a soft reset?
DSL uptime:42 days,00 Hours31 Mins27 Secs
Data rate:5.896 Mbps / 29.997 Mbps
Maximum data rate:6.101 Mbps / 40.083 Mbps
Noise margin:6.5 / 8.3
Line attenuation:37.6 / 25.1
Signal attenuation:24.6 / 22.5
Message 10 of 14
Re: Banded profile
NO
I have asked mods to see if they can help as you have 42days connection time
