Message 1 of 8
Bypass BT Home Hub?
Hello,
Apologies for, potentially, a really lame (stupid) question;
I am in new build with FTTP my existing wifi isn't cutting it around house so decided to upgrade, I have gone down route of Ubiquiti (UDM-Pro, USW-Pro-24-POE Gen 2, 3 nanoHD AP's).
So, to that end, I have no need to any of features BT hub provides aside from connectivity. Can I just buy old Openreach fibre modem off eBay that cuts all the 'fancy features' out and just acts as VDSL2 modem?
Or for that matter could I buy any VDSL2 Modem? eg. DrayTek Vigor 130
Thank you in advance
-G
7 REPLIES 7
Message 2 of 8
Re: Bypass BT Home Hub?
if you have FTTP then the ONT already installed is the modem  you just need a router with a WAN port
Message 3 of 8
Message 4 of 8
Message 5 of 8
 keeps failing... what am I doing wrong?
Message 6 of 8
VLAN must be 101.
Message 7 of 8
VLAN should be off with FTTP.
Message 8 of 8
Forget what I said then. Any suggestions, as I am not familiar with FTTP?
DNS settings possibly, may be best to use BT ones to start with.
