Message 11 of 21
Re: Broadband Speed Comparison
pippincp  I attempted to upload info but the photo didn't like the format.
meanwhile the connexion speed showed 140 Mbps.
I will post again when I've sorted out the saved format
Studon
Message 12 of 21
Both .jpg and .png are acceptable formats. If file size is a problem use an online optimiser to reduce the file size.
Message 13 of 21
Here is the info you requested.
StudonOpera Snapshot_2021-02-13_175053_fast.com.pngOpera Snapshot_2021-02-13_175334_192.168.1.254.png
Message 14 of 21
You've cut oout a chunk of the technical log.
Message 15 of 21
pippincp
Hopefully here is an uncut version of the technical log.
Studon
Message 16 of 21
connection speed from hub stats is as expected 330/50mb
are you running your speed tests using ethernet cable from hub direct to your device - not wireless
Message 17 of 21
imjolly
I use ethernet cable (cat5e) for testing and general usage at all times.
Studon
Message 18 of 21
imjolly
Regarding connexion speeds, how can I get my speed restored to what BT stated what I could expect to achieve
 Studon
Message 19 of 21
So as far as I can see, the connection between your hub and the cabinet is correct at 330/50
But when you test it, your getting about 140/30 ish
The problem now is knowing exactly what is causing this. It could be a myriad of things, from the smart hub itself to the computer you use to test.
You are going, HUb>cat5>Laptop ?
Is the laptop's ethernet port 100mbps or 1000mbps, its also possible that the cat5 cable is not allowing a 1000mbps negotiated connection, need to check that link is full speed so click on the ethernet icon, open network & internet settings and then choose properties then scroll down and have a look at link speed (received/connect) and ensure it says 1000/1000
Then, make sure nothing is connected to the hub so unplug everything else and turn off wifi.
Make sure your computer is not doing anything else (like doing an update etc, on windows 10 use taskmanager and make sure CPU and disk activity is really low.
Then test again and let us know.
Message 20 of 21
Gary C
For testing, Master Socket 5C to Hub, Cat 5e to Lap Top
In Settings / Internet /Properties link speed(receive/ transmit) : 1000/1000 Mbps
Speed test on BTW Performance tester  is 147 Mbps down / 48 Mbps up.
Studon
