Message 11 of 13
Re: Broadband Speed
Hmmm, those speed test results on your phone seem to be pointing towards a potential issue as it states you're not getting the speeds expected to the hub
Message 12 of 13
Re: Broadband Speed
according to dslchecker your range is 50/33mb and currently you are getting 43mb with an attainable of 45mb so well within expected range.
if you are dropping connection often and have noise on your line then report a phone fault to 151
Message 13 of 13
Re: Broadband Speed
Okay, will call 151.  I found a ethernet cable and connected to my Hub & Computer.  Did that test and it showed:
Sorry, this is all I can show.  If you say I'm getting 43Mb, why is the ethernet data now at 28Mb.  Anyway, last post - Thanks again...
