Message 1 of 8
Broadband and landline over fibre optic cable ?
I am just about to have FTTP from telegraph pole to my house. (Halo 3)  I have an existing landline on overhead copper wire line.
I was under the impression the copper line would be removed and my broadband and also my phone line would run through the new fibre optic cable?  Is this not possible as I don't  want any more overhead cable  running overhead my garden due trees etc ( I already have the neighbours cables ) It wasn't the impression I got when I ordered it as my other option was Virgin which uses underground fibre from my front gate including phone line
7 REPLIES 7
Message 2 of 8
Re: Broadband and landline over fibre optic cable ?
Even if your phone and broadband are supplied by fibre, Openreach don't currently remove the redundant copper cable unfortunately. Are you definitely getting Digital Voice, you might still be getting telephony via the copper cable, Digital Voice is not yet universal.
Message 3 of 8
Thanks, no digital voice yet so stuck with two overhead cables
Message 4 of 8
AFAIK, if your current service is delivered by an overhead dropwire and you are getting ‘overhead’ FTTP, they may use a shotgun cable where is  a copper pair and fibre  in the one cable , if you are keeping telephony over the copper pair they in effect transfer the copper pair service into the new shotgun cable , and the old copper pair dropwire can be taken down so you still only have the one ‘new’ dropwire , containing  both the copper and fibre services
Message 5 of 8
Excellent, I'll ask the guy if its possible 😉
Thanks for info
Message 6 of 8
It is one cable . The fibre and copper are bound together. Well that is what happened with my install.
Message 7 of 8
thanks very much
Message 8 of 8
@iniltous @spile  The "Shotgun" cable has been discontinued, only areas that still have stocks are using it up. Even where still used the existing copper line is left intact.
Moves are afoot for existing copper lines to be removed in the furture once PSTN has been retired.
