Message 1 of 3
Split 2.4Ghz and 5Ghz bands
Hi there,
I am having trouble connecting my Sonos to my network, is there a way to split the 2.4ghz and 5 ghz network so I can connect to each independently on different devices?
Or, is there a way to force a device to use a certain network in the BT hub manager?
2 REPLIES 2
Message 2 of 3
Re: Split 2.4Ghz and 5Ghz bands
If you have a SH2 then you cannot split the networks.  If you have problems connecting to 2.4ghz network then turn of the 5ghz network then connect 2.4 device and once connected re-enable 5ghz
Unlikely you can decide whether to. Connect to 2.4 or 5ghz
Message 3 of 3
Only devices themselves can be forced to use one band or the other, it can't be done by the hub.
