Message 11 of 12
Re: Broadband connection keeps dropping
the most basic test for problems with your broadband is to check the phone line to see if there is a dial tone and then to see if there is any noise on the line  line noise is the most common cause of an unstable connection
can you borrow a phone?
without most basic test making changes may make matters worse
Message 12 of 12
Did you ever resolve this issue? Having something similar. Cheers
