Message 1 of 3
Broadband home map
Help, is there a way to view what devices are attached/running on your broadband?  I'm sure I saw something that gives a map of everything that is being run on your router.  I have looked om my BT but nothing seems to stand out.  tia
2 REPLIES 2
Message 2 of 3
Re: Broadband home map
Assuming you have a BT hub, go to the hub manager 192.168.1.254 and select My Devices
Message 3 of 3
Access your hub in a browser, e.g. http://192.168.1.254/  for Smart Hub 2, then click on "My Devices".
