Message 1 of 5
Broadband speed is great but it takes forever to actually load anything
Hi All, wondering if anyone has any advice. We've had BT internet for about 2 weeks now, no problems setting up. If I test the speed on any device it comes to around 25mbps. The problem is even though the speed is fast, 80% of the time it is unusable. It loads the initial part of a webpage no problem, for example it will load the amazon logo and the general outline of the page, but it will then take 4 or 5 minuets to populate the rest of the text or images on the page. This is the same across all devices that use a browser. The alexa's just dont work, they show as loading for a bit and then give up. We have a roku tv stick that takes about 20 minutes to get to the point of actually streaming (it then maintains the stream no problem).
Im at a bit of a loss on what to do and wondered if anyone has any ideas on what this is or how I can approach fixing it
4 REPLIES 4
Message 2 of 5
Re: Broadband speed is great but it takes forever to actually load anything
have you turned of smart setup
Turn Off smart setup
check MYBT and turn off web protect
Message 3 of 5
Thank you for your help. Web protect is off, I've switched off smart setup but that hasn't helped
Message 4 of 5
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 5 of 5
Hi imjolly
Here are results as follows
Techincal Log :
Product code:Smart Hub 2
Serial number:+091298+2041005544
Firmware version:v0.24.04.11017-BT
Firmware updated:Fri Jan 29 08:43:54 2021
Board version:R01
GUI version:1.71 05_06_2020
DSL uptime:0 days,04 Hours25 Mins24 Secs
Data rate:5.786 Mbps / 28.541 Mbps
Maximum data rate:5.661 Mbps / 34.567 Mbps
Noise margin:5.7 / 6.2
Line attenuation:6.4 / 23.3
Signal attenuation:5.1 / 24.5
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:155.9 MB Uploaded  / 1.5 GB Downloaded
Broadband username:[email protected]
BT Wi-fi:Activated
2.4 GHz wireless network name:BT-28ASCP
2.4 GHz wireless channel:Smart (Channel11)
5 GHz wireless network name:BT-28ASCP
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2 (Recommended)
Wireless mode:Mode 1
Firewall:On
MAC address:E4:75:DC:98:2A:3F
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017)
Quiet Line - Normal
Broadband Checker Results
Telephone Number  on Exchange CONISBROUGH is served by Cabinet 3
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability Date Left in JumperHigh Low High Low        VDSL Range A (Clean)
VDSL Range B (Impacted)
32.424.26.74.820AvailableAvailable--
32.4206.64.315AvailableAvailable--
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessFTTP on Demand
33030--Available--
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date WBC SOADSL Availability Date Left in JumperWBC ADSL 2+WBC ADSL2+ Annex MADSL MaxWBC Fixed RateFixed Rate
Up to 8--5.5 to 15AvailableAvailable--
Up to 8Up to 15.5 to 15AvailableAvailable--
Up to 4--3 to 5AvailableAvailable--
2----AvailableAvailable--
2----Available----
Observed Speeds ADSLMax Observed Downstream SpeedMax Observed Upstream SpeedObserved Date
12.68
1.25
2019-11-04
Other Offerings Availability DateVDSL MulticastADSL Multicast
Available
Available
Premise Environment StatusBridge TapVRINTE FacePlateLast Test Date
U
05-02-2021
Exchange Product Restrictions StatusFTTP Priority ExchangeWLR WithdrawalSOADSL Restriction
N
N
Y
The premise/line is associated with exchange which is NOT part of current fibre priority programme.
The premise/line is associated with exchange where WLR is not withdrawn.
The premise/line is associated with exchange where SOADSL service is restricted.
FTTP is not available.
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
The Stop Sale date for IPstream is from 31 Oct 2012. The Formal Retirement date for IPstream is from 30 Jun 2014.
Any help is appreciated greatly.
