Message 1 of 15
Broadband speed reduction after reconnection
Hi.  So am on Fibre 1 and have been for a few years now.  My speed specified by BT is up to 47mbps which it does often achieve.  I made the silly mistake of moving to another provider but 3 days after choosing to switch I decided to switch back to cancel and stay with BT.  Contacted both and everything was cancelled.  However on the day it should have switched I lost my broadband and after a lot of time on the phone to BT they said I had been Slammed which means the other provider had taken the line.  BT the arranged a re connection and after 7 days I am back up and running.  However the speed they now give is up to 37mbps.  2 weeks ago and prior to my switch they were giving me up to 47mbps.  But no longer offer that according to their website.  What should I do?
If I went with BT business they are offering 47mbps on the same line.  All seems very odd.  Would they have reconnected me On a different circuit than before??
14 REPLIES 14
Message 2 of 15
Re: Broadband speed reduction after reconnection
maybe you should have a business line if you are running a business on a residential line
can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number  but leave exchange and cab https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 3 of 15
Hi @imjolly   Thank you for your prompt reply.  I will do the tests and post the stats.  However my question really is why would BT have reduced their offering on the same line.   When I was looking 2 weeks ago they were quoting up to 47mb which is what I used to get.  Now my new order confirmation states up to 37mb where as 2 weeks ago they quoted 47mb.  Does that make sense??
The reason I mention business is that on the same lone they offer what I previously had.
Message 4 of 15
when you post the results from dslchecker we will see what the estimates are for your line  these estimates are supposed to be realistic based on other customers in your are
Message 5 of 15
@imjolly   Here you go!
Message 6 of 15
Your estimated speed is 51/35mb and you had 43mb on 30/6
Can you post the exchange and cab which you have deleted
hub stats will be good as well
Message 7 of 15
@imjolly   Exchange is Seaton.  Cabinet 10
Message 8 of 15
@imjolly   Sorry forgot hub stats
Message 9 of 15
Sorry but the stats are from advanced settings then technical log information which is not the ones posted
Message 10 of 15
@imjolly   Is this what you need?
Product code:Smart Hub 2
Serial number:+091298+1922022329
Firmware version:v0.17.01.12301-BT
Firmware updated:Mon Mar 9 07:49:11 2020
Board version:R01
GUI version:1.56 15_02_2019
DSL uptime:0 days,16 Hours58 Mins17 Secs
Data rate:9.999 Mbps / 40 Mbps
Maximum data rate:12.290 Mbps / 49.579 Mbps
Noise margin:8.8 / 9.6
Line attenuation:12.3 / 20.9
Signal attenuation:12.3 / 29.0
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:180.9 MB Uploaded  / 2.2 GB Downloaded
Broadband username:[email protected]
BT Wi-fi:Activated
2.4 GHz wireless network name:AJPHUB-5
2.4 GHz wireless channel:Channel: 11
5 GHz wireless network name:AJPHUB-5
5 GHz wireless channel:Channel: 44
Wireless security:WPA2 (Recommended)
Wireless mode:Mode 1
Firewall:On
MAC address:04:A2:22:1A:84:18
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017
