Message 1 of 2
Broadband dropping out every few minutes
I have a BT Smart Hub 2.
My hub is dropping out every few minutes, and nothing I do has solved this problem. There was a lot of noise on my phone this morning, the cable was originally running under the carpet through the gap in the corner of the door (so I could have it on the landing) but I have set the phone up now, next to the phone socket and the line is now clear. This has not fixed the broadband problem however.
I have unplugged absolutely everything from the hub, and I have unplugged the phone. I have tried running just the hub through the test socket but nothing works. I have also changed the adsl cable to the Hub. I have checked if there are issues in my area, and there are not.
any ideas?
1 REPLY 1
Message 2 of 2
Re: Broadband dropping out every few minutes
Hopefully it’s sorted itself.
