Message 11 of 18
Re: Broadband speed
When going into broadband checker ,enter tel.no. As soon as I enter 01661 it comes up as no. Invalid.When trying address checker it just freezes.
Why can't you do the speed check?
John
Message 12 of 18
Re: Broadband speed
are you a bt broadband customer?
Message 13 of 18
Re: Broadband speed
The broadband checker reports an "invalid number" until you enter the complete number.
Message 14 of 18
Re: Broadband speed
I did enter full number & The same reply came up,no.  invalid.
Message 15 of 18
Re: Broadband speed
are you a bt broadband customer  if not that would be one reason checker does not work
Message 16 of 18
Re: Broadband speed
Yes I am
Message 17 of 18
Re: Broadband speed
post hub stats
if hh5 then troubleshooting then helpdesk
if hh6/SH2 then advanced settings then technical log information
check quiet line test  dial 17070 option 2  should hear you number repeated and then should be silent  best with corded phone
Message 18 of 18
Re: Broadband speed
if you are a bt broadband customer the dslchecker should work and give results
try your address
