Message 11 of 17
Re: Broadband speed
so it is connected to test socket
try quiet line test  dial 17070 option 2  should be silent and best with corded phone
Message 12 of 17
Re: Broadband speed
You don’t appear to have a phone plugged in , as already advised you probably need to do a quiet line test and if any noise present report it , a noisy line would affect your broadband, your speed does seem to be well below what the line would be expected to deliver, you could always call your provider and ask them the check
Message 13 of 17
Re: Broadband speed
Hi, unfortunately we don't have any or use the house phone. Is there any other way around this?
Message 14 of 17
Re: Broadband speed
no
the most basic check when you have broadband problems is to ensure you have a dial tone and also if line silent - no noise
Message 15 of 17
Re: Broadband speed
What do you recommend me to do now to fix my speed?
Message 16 of 17
Re: Broadband speed
the best way would be to get or borrow a phone to test your line
you can always phone customer services and get engineer visit but if problem in your home wiring or setup then you will probably be charged £85 for callout  there is no charge if problem outside you home which the line test would establish
Message 17 of 17
Re: Broadband speed
There appears to be 2 cables connected to the master socket, if so the master has been wrongly wired. Any  extention should connect to the faceplate.2020-06-12 17_34_31-Broadband speed - BT Community.png
