Message 1 of 6
Broadband suddenly is much slower
I reported a fault on April 2nd where the connection was intermittent, BT sent an engineer and he came and replaced the master socket with a pre-filtered one. This sped up my internet from around 40mbps down to around 60mbps down however the internet still frequently drops and recently the speeds have not been above 10mbps.
5 REPLIES 5
Message 2 of 6
Re: Broadband suddenly is much slower
@Viacal
Do you have a phone connected to the socket?  If so is it wired or wireless?
Dial 17070 select the option for Quiet Line Test and see if you get any noise, IF it's cordless u may get a hum that's fine.
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 3 of 6
welcome to the BT community forum where customers help customers and only BT employees are the forum mods
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 4 of 6
Hi there, i dialed the number and I hear nothing I have a corded phone plugged into the pre-filtered master socket.
Message 5 of 6
That's good.  Can you post the rest of the information I requested
Message 6 of 6
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability Date Left in JumperHigh Low High Low        VDSL Range A (Clean)
VDSL Range B (Impacted)
G.fast Range A (Clean)
G.fast Range B (Impacted)
8069.8201964.5AvailableAvailable--
8067.2201961.2AvailableAvailable--
3303305043.5315AmberAmber--
330324.75031.3300.2AmberAmber--
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessFTTP on Demand
33030--Available--
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date WBC SOADSL Availability Date Left in JumperWBC ADSL 2+WBC ADSL2+ Annex MADSL MaxWBC Fixed RateFixed Rate
Up to 15--8.5 to 19AvailableAvailable--
Up to 15Up to 1.58.5 to 19AvailableAvailable--
Up to 7--6 to 8AvailableAvailable--
2----AvailableAvailable--
2----Available----
Observed Speeds VDSLMax Observed Downstream SpeedMax Observed Upstream SpeedObserved Date
13.09
2.69
2020-06-05
Other Offerings Availability DateVDSL MulticastADSL MulticastG.fast Multicast
Available
Available
Available
Premise Environment StatusBridge TapVRINTE FacePlateLast Test Date
N
N
N
13-05-2020
