Message 1 of 13
Bt hub 2 swap for netgear nighthawk
Hello just after a bit of help  got my fibre install today working great but the home hub wireless and speed not cutting It I’m thinking of  swapping it for the nighthawk RAX200 I was using on my virgin media set what I would like to know would my parental setting still work if I remove the home hub
12 REPLIES 12
Message 2 of 13
Re: Bt hub 2 swap for netgear nighthawk
@omar_r6
Depends what fibre you've got as the Nighthawk is just a router, so if you've got fibre to the home with a separate modem (ONT) it'll work otherwise not.
If you've got G.Fast then there's only one3rd party  modem/router that seems to support that and that's the Asus DSL-AC88U.
So what fibre do you have?
Message 3 of 13
Full fibre 900 fibre to the house and it’s on the wall with a box with my old virgin media I was able to use my netgear night hawk and still have my virgin media parent settings working, But with Bt I don’t know if it will work I want to use my netgear and still have the Bt parental controls working.
Message 4 of 13
your netgear should work with ONT settings need to be pppoe with username [email protected] and any password
did you get digital voice when you got FTTP installed?  if so then it will only work with SH2 connected as hub is a dect base station for phones
Message 5 of 13
@omar_r6  Router based parental settings will still work, network based parental settings will require the use of BT's DNS servers.
Message 6 of 13
@imjolly didn’t get a digital phone just the broadband only.
Message 7 of 13
@TimCurtis Full fibre 900 fibre to the house and it’s on the wall with a box with my old virgin media I was able to use my netgear night hawk and still have my virgin media parent settings working, But with Bt I don’t know if it will work I want to use my netgear and still have the Bt parental controls working.
Message 8 of 13
See message 5
Message 9 of 13
Hello, im in the process of doing the same type of thing, I have a bt home hub 2 on 900mbs but the outcome from the router is only 450 BT engineers have been here and advised trying a new router. I have tried the Nighthawk AX6600 that then brings my speeds to 700-800 so thats that side fixed.
Next problem as you asked about is the digital phone that now wont connect. I have an ethernet form the router to the home hub the light on the disk is blue the phone registers but cant accept or make calls, please explain how I can fix this and what is the SH2 thank you
Message 10 of 13
@Llionj
The Digital Phones will only connect to the Smart Hub 2 (SH2) using DECT, which has to be the one directly connected to the Optical modem, it cannot be connected via another router.
