Message 11 of 13
Re: Bt hub 2 swap for netgear nighthawk
@Keith_Beddoe thanks Keith, that is what im wanting to do, so the wan is connected to the netgear then an ehternet to the home hub, i run the setup process for the hub it completes it says connected but the light is orange and when i setup the phone it runs through it all but at the end says cannot send or receive calls thanks
Message 12 of 13
@Llionj
No it will only work the other way around, the WAN has to be connected to the Smart Hub 2, to allow BT Digital Voice to do secure authentication, otherwise you cannot make or receive calls.
Message 13 of 13
@Keith_Beddoe  thank you for the advice
