Message 1 of 3
Bt store
I have bought a 2021 I pad a few days ago I was told there was 40 in stock I have gone on the store to check on the progress of it and now I’m told there is none in stock has anyone got any idea when they will be back and if it will be before Christmas? Thanks In advance
Tags (1)
2 REPLIES 2
Message 2 of 3
Re: Bt store
@Jack_G
The BT Shop, is totally separate from BT Phone and Broadband.
Try https://shop.bt.com/Help
Message 3 of 3
Re: Bt store
Hi @Jack_G and welcome to our community.
I'm sorry there's been some confusion with your BT Shop order. @Keith_Beddoe advice is correct. If you contact the shop help team they'll be able to advise further. Let me know how you get on.
Cheers
David
