Message 1 of 4
By monitor replacement parts
I am trying to find a replacement part for my bt smart monitor. I have broken the stand on the back and looking to replace just that part.is this possible? Please help.
3 REPLIES 3
Message 2 of 4
Re: By monitor replacement parts
@Danielledudd
I doubt you could just obtain that bit, but you could try Discomm, and see if they can help.
Search for them on Google, they are BT spares supplier.
Message 3 of 4
Hi there
I’ve done exactly the same thing! Did you manage to find a solution?
Thanks in advance!
Message 4 of 4
No unfortunately not, I could not get the part anywhere. However I had purchased it through Amazon and after contacting them through the repair/return function, they sent me out a replacement as it was still in warranty.
