Message 1 of 7
CSP to ONT
Quick one I dont want the cable run from the CSP outside my house  internally to the ONT as it will look usightly.
Can this cable be run externally from the CSP at the front of my house to the side and drilled into a first floor wall into a study?
If so can the cable colour be white?
6 REPLIES 6
Message 2 of 7
Re: CSP to ONT
There's no choice of fibre cable colour. It can be run externally.
Message 3 of 7
Re: CSP to ONT
What Colour is the cable?
Message 4 of 7
Re: CSP to ONT
Black I think. You could always run an thernet cable for an ONT fitted downstars up to your study/office and have the hub up there.
Message 5 of 7
Re: CSP to ONT
Trying to avoid any internal cabling hence taking it externally to the point where it will come in.
Message 6 of 7
Re: CSP to ONT
You can get external ethernet cable.
Message 7 of 7
Re: CSP to ONT
The old EZ Bend Cable for Legacy Fibre came in a choice of White, Brown or Black.
The new EZ Bend Cable they use for what Openreach call, Inside-Out comes in a choice of Black, Dark Black and Really Dark Black.
The Engineer may have some old stock of White EZ Bend on his van or he may not.
