Message 11 of 11
Re: Cable Spec
Thank you Iniltous, It will not be registered as a separate building but will have its own separate broadband independent from the main house. Therefore as another member has suggested, I will run the ducting underground from the distribution point (pole) adjactent to the main house to the workshop, with a draw cord,and Openreach will supply and pull the cable.
