Message 1 of 8
Can’t Blacklist numbers on BT Caller logs
Hi ,
I’ve been using the Blacklist function for a couple of years and I have backlisted x  85 numbers in my BT account.
However, 3 x months ago this feature no longer works.
You can view your recent landline number calls but when you click on Blacklist it doesn’t work .
Anyone else having the same problems 🤔
7 REPLIES 7
Message 2 of 8
Re: Can’t Blacklist numbers on BT Caller logs
Hi, @philip_startrek welcome back to the community and thanks for posting, I'm sorry to see you're having problems adding new numbers to your call protect blacklist. When you're adding a number are you getting an error message?
Neil
Message 3 of 8
Hi Neil,
No error messages at all.
When you view Recent Callers you used to be able to click on “More” a drop down box used to appear which included Blacklist the number . I’ve got 85 Blacklisted numbers upto date.
when you click on “More” nothing happens.
Philip
Message 4 of 8
Hi, @philip_startrek thanks for getting back to me, would it be possible for you to try on an alternative web browser and let me know if that works?
Neil
Message 5 of 8
Hi ,
I normally use my BT App on iphone to Blacklist the numbers.
philip
Message 6 of 8
@philip_startrek no worries, can you try deleting and reinstalling the MyBT app?
Neil
Message 7 of 8
Hi ,
Deleted App and reloaded it but still doesn’t work.
Regards,
Philip
Message 8 of 8
Hi @philip_startrek
I can't blacklist through the app on my iPhone either so I would suggest that a bug has been introduced in one of the updates.
You can still blacklist by logging into bt.com on a browser, although I've only tried on a laptop.
