Message 1 of 3
Can't connect to league of legends
Hi new to the bt forums, I had an issue recently where I can't connect to the league of legends servers. I have talked with riot support and they assure me its a routing issue and only BT (openreach) can fix, I'v also spoken to BT support via phone and the lady said they can only deal with at home broadband issues and she can't raise this issue to someone higher so here I am looking for any help I can get.
2 REPLIES 2
Message 2 of 3
Re: Can't connect to league of legends
Make sure web protect isn't enabled in MyBT
Message 3 of 3
I solved the issue, wasn't connection related even though Riot support convinced me otherwise (was a gfx card issue) consider this solved/closed
