Message 1 of 13
Can't subscribe to Fibre 1
BT can't seem to tell me why I can't subscribe to Fibre 1 in the DA16 area. They've told me that the area is being upgraded to FTTP and it will be the same price as FTTC, which I believe is untrue.
An ex BT engineer friend has told me that the most likely reason is that the green cabinet is full to capacity.
If so, how do I get BT to upgrade the cabinet?
12 REPLIES 12
Message 2 of 13
Re: Can't subscribe to Fibre 1
For a given service, the price is the same regardless of how it is delivered.
Quite possibly. If you enter your phone number in the checker and post a screenshot of the result, we will be able to tell you. Remember to delete your number from the screenshot before posting.
Nothing to do with BT, it is Openreach. If they have plans for FTTP they are extremely unlikely to increase capacity in the cabinet.
Message 3 of 13
Message 4 of 13
Can you post the requested screenshot please.
Message 5 of 13
That brief message is the screenshot!
Message 6 of 13
That is not the screenshot requested. Read @licquorice post again and click the link given.
Message 7 of 13
Message 8 of 13
Use your address, as presumably you don't have a BT line, or if you have, don't leave any spaces when entering the number.
Message 9 of 13
I don't have aPolish_20200828_200543636.png BT line now I'm with Virgin.
Message 10 of 13
That explains why you cannot get FTTC from BT or any other ISP. Your cabinet has not yet been upgraded for fibre
