Message 11 of 19
Re: Can't swap from Fibre 2 to Full Fibre 100
I wish I was lucky enough to need to phone the FTTP TEAM🙂
many others get referred to FTTP TEAM with a few having the same problem as you but perseverance paid off
Message 12 of 19
so you haven't actually be tried it yourself then 🙂
Can I suggest that before being certain, you do?
I am not stupid.
Message 13 of 19
Phil just call 0800 800 150 press option to track an order when your connected just ask to be transferred to FTTP team. Life to short for all this messing around lol
Message 14 of 19
I am not stupid.
Not stupid but possessing a very short fuse. The guy is NEITHER a BT nor Openreach employee and is simply a  customer volunteering his free time.
Have you tried calling since?
Message 15 of 19
I have called this number numerous times, at all times. If people who haven't called it even once persist in telling me that my experience is wrong, perhaps it's that that informs my response rather than "a short fuse".
I take it you haven't actually called it either 🙂
Message 16 of 19
I just made a comment that the number people keep recommending doesn't currently do what they think.
I was trying to be helpful.  I won't make that mistake again.
I
Message 17 of 19
Hi @Phil_Wales,
Thank you for posting. I'm sorry if you haven't been able to get through to the FTTP when calling 0800 587 4787.
That is the correct number for the FTTP team but they are busier than normal recently. When that number is busy, calls do get routed through the normal 150 call queue.
If you send me your details, I'll take a look at this for you to see if I can help you with that order.
I have sent you a private message with instructions on how to contact the team.  You can access your messages via the envelope icon at the top right of the screen, or click on this link, Private messages
Thanks,
Paddy
Message 18 of 19
Thanks. It's resolved now.
The issue was a data integrity error, as in a difference in records between BT and OR.
It took three passes for them to wrinkle out the issue, and it finally happened today. 149 Mb down, 30 up. So that's good.
Not so good that it took 1 month and a half to resolve a simple change from one fibre product to another, , but it's not as if I was without service of anything, so it's not the end of the world. Just a lot of wasted time for all concerned.
Message 19 of 19
Hi @Phil_Wales,
Thank you for posting back to update the thread.
I'm sorry it wasn't an easy fix but I'm glad you managed to get sorted in the end.
Thanks,
Paddy
