Message 1 of 6
Car Bluetooth
Trying to connect iphone XR to car bluetooth but car keeps asking for the bt bluetooth pin code is there a default code for bt phones any help would be appreciated thanks
5 REPLIES 5
Message 2 of 6
Re: Car Bluetooth
@worthog567
I think you are confusing BT Retail with bt (Bluetooth).
What its is asking for is the Bluetooth (bt) pairing code, which would normally be displayed on your device. The car Bluetooth would request a pairing code to confirm that its the device you want to pair with.
This has nothing to do with BT Retail.
Message 3 of 6
Re: Car Bluetooth
Ok thanks anyway. Was just hoping someone else had come across this trying to connect to car with bt phone. You are correct that the car is asking for bt Bluetooth pin code but there’s no code coming up on the phone thanks
Message 4 of 6
Re: Car Bluetooth
Its possible being displayed as a notification message on the iPhone, and you cannot see it. Perhaps someone with an iPhone can tell you where its likely to show these messages.
On my Android phone, it appears as a popup notification and displays a code, if I try to pair another device.
Message 5 of 6
Re: Car Bluetooth
Thanks I’ve just sorted it out tried 0000 in the car then the phone asked for pin so put 0000 in the phone as well and it connected so done now thanks again for help
Message 6 of 6
Re: Car Bluetooth
Plenty of other people have assumed that bt had something to do with BT, even non-BT customers.
