Message 1 of 2
Change from BT Virus Protect McAfee to BT Virus Protect Norton
I see BT Virus Protect has changed from McAfee to Norton when installing on new laptop. Should I change it from other 2 devices (PCs). How long will McAfee be supported.? No notification from BT, just found out about the change by accident. Any thoughts on this. Thanks.
1 REPLY 1
Message 2 of 2
Re: Change from BT Virus Protect McAfee to BT Virus Protect Norton
See links
What is BT Virus Protect and how do I get it? | BT Help
Important updates to your virus and password prote... - BT Community
and all the other posts on the forum about the change and any problems you may have.
