Message 1 of 3
Changing a Home Hub 5 (Type A) to Smart Hub 2
Evening
Our Home Hub 5 (Type A) has become very noisy and problematic, with multiple WiFi disconnections.
I've bought a new Smart Hub 2 privately and wondered if there was anything I should do before simply disconnecting one and plugging in the other? Any settings worth noting in the Home Hub 5 before switching over?
Thanks for any assistance.
2 REPLIES 2
Message 2 of 3
Re: Changing a Home Hub 5 (Type A) to Smart Hub 2
Turn off Smart setup on the SH2.
You can't give the wifi bands separate SSIDs on the SH2 but if you haven't split the bands on the hub 5 it might be easier to change the SSID on the SH2 to match that of the Hub5 rather than change all your devices to a new SSID.
Message 3 of 3
Thanks for the super quick response,
We haven't split the bands on the Home Hub 5 and didn't give the SSID a name, so it looks like, other than switching smart hub off, it should be pretty easy.
Fingers crossed and thanks again.
