Message 1 of 22
Cloud Dashboard will not open on iMac after installing update 20.3.10
Hello,
I have just installed Cloud app update 20.3.10 on my iMac running iOS 10.12.6.  The cloud icon appears in the system bar and syncing occurs but the dashboard will not open.  Clicking on the icon just causes the app to exit.
All help gratefully received.
Thank you.
21 REPLIES 21
Message 2 of 22
Re: Cloud Dashboard will not open on iMac after installing update 20.3.10
Click on the icon in the top bar then click in the cog wheel. If its crashing try a reinstall.
Message 3 of 22
Hello Dode,
Thanks for your reply.  When I left or right click on the icon it disappears.  I have tried a reinstall but no luck.
Regards,
John
Message 4 of 22
Sounds a bit elementary but have you tried uninstalling the app. then restart the iMac before reinstalling.
Message 5 of 22
Same result, I'm afraid.  I did a complete power down, just to be sure.
Message 6 of 22
When you uninstalled it did you remove the preference file at the same time;
User>Library> Preferences>com.bt.btcloud.plist
Message 7 of 22
No, I didnt. Searching now, I cannot find any file named com.bt.btcloud.plist on the system.
Thanks for your perseverance,
John
Message 8 of 22
Exactly the same problem.Dashboard   option  not in menu drop down from top bar.No way to acess shortcut, and notifications not working as before, Mac OS 10.15.5
Message 9 of 22
Hello CD179,
BT Tech Support contacted me directly and recorded the problem occurring on my system.  They are currently analysing the problem.
Regards,
John
Message 10 of 22
Morning, I reported my problem yesterday and got a VOLxxxxxxxxx fault report number and a promise of a reply.
I used to get notifications of everything that happened on the cloud on my side bar, and now nothing. Is yours the same?
Chris
