Message 21 of 25
Re: Company domain blocked by BT while it's showing up as clear everywhere else.
Thank you so much @JohnC2 for making it happen and @Will168 for checking to confirm.
Best Regards
Francois
Message 22 of 25
Hi John,
Hope you are well
I also have the same problem with my domain www.averlogistics.com   & www.averlogistics.co.uk
Could you please help with the same fix, we are loosing customers due to this incorrect category
Message 23 of 25
@steveaverlogistics
Both sites are identified as Phishing sites, by OpenDNS, so its not surprising that BT are blocking them. You need to find out why.
I would advise forum members not to visit these sites.
Message 24 of 25
Hi Keith,
 I’m trying to get the sites white listed they have been incorrectly listed. We have no idea why the website was listed like this and there is 100% no issues with our website, we are just a small UK freight forwarder and this is affecting our sales. Some advice would be good or at least a contact at bt so we can report this false positive.
Message 25 of 25
@steveaverlogistics
Sorry, I cannot help, I am just a BT Retail customer. If you are 100% sure that your website has not been hacked, then I am not sure why OpenDNS is flagging it. I use OpenDNS and not the BT DNS servers, and they do not normally give false positives.
