Message 1 of 10
Confused with Broadband speeds
I am coming to the end of my contract with BT. My current speed (according to the speedtest)  is 35.5mb/s. However, when I look at what is available for me I am offered between 5-11mb with a stay fast guarantee of 3mb. Well down on my current contract. Even more confusing is that my next door neighbour (in a semi) is approaching 70mb with BT.
I recently had an engineer out to fix a phone line problem and he suggested, now the phone problem is fixed, we should be able to get a similar speed to our neighbour.  Can anyone shed any light on what might be going on or how this can be resolved?
9 REPLIES 9
Message 2 of 10
Re: Confused with Broadband speeds
post hub stats  if hh5 then troubleshooting then helpdesk  if hh6/SH then advanced setting the technical log information
enter your phone number and post results  remember delete number
Message 3 of 10
Product nameBT Smart Hub 2
Serial number1924101740
Fireware versionv0.17.01.12312-BT (Mon May 11 18:49:53 2020)
Board versionR01
GUI version1.56 15_02_2019
DSL uptime0 days 1 Hours 27 Mins 0 Secs
Data rate7.9 Mbps / 35.0 Mbps
Maximum Data rate8.2 Mbps / 47.5 Mbps
Noise margin6.1/11.1
Line attenuation10.4/22.0
Signal attenuation10.4/22.5
VLAN id101
Upstream error controlOff
Downstream error controlOff
Data sent / received54.6 MB Uploaded / 145.5 MB Downloaded
Broadband username[email protected]
BT Wi-FiActive
2.4 GHz wireless network nameBT-XPA8MF
2.4 GHz wireless channelSmart (Channel11)
5 GHz wireless network nameBT-XPA8MF
5 GHz wireless channelSmart (Channel36)
Wireless SecurityWPA2 (Recommanded)
Wireless modeMode 1
FirewallOn
MAC address04:A2:22:3B:86:69
Software variant-
Boot loader 0.1.7-BT (Thu Nov 30 09:45:22 2017)
Message 4 of 10
from what you have posted your estimated connection speed range is 51/35mb and currently from hub stats you are getting 35mb.  However you obviously have been having connection problems probably with connection dropping often and you are now in a banded profile at 35mb with high noise margin of 11db - normal about 6db
your connection time is only 1 hr is that due to router dropping connection or manual reset of hub?
did you try quiet line test
Message 5 of 10
The problem could also be due to powering off the router & hub when not in use.
My friend did doing cartwheels after I told him to leave both the above powered on even when on holidays (remember them?). It took about 8 to 10 days to get up to a decent speed.
My friend now believes I am a real expert but, in actual fact, I learned that and much else on this forum!
Message 6 of 10
Hi thanks for coming back. The downtime this morning was an hour with the orange lights flashing on the Smart Hub2, and me turning it of and starting it on again, We do seem to have the connection dropping in and out quite a bit.
I have just done a quiet line test and there is a constant buzzing sounding the background.
Message 7 of 10
You have a line fault. Report a noisy line.
Message 8 of 10
thanks for the advice, it is good advice. We do tend to leave the router turned on permanently unless we get a situation where we lose our connection or the router seems to be unresponsive.
Message 9 of 10
Reported fault and the diagnostics  bot has advised that there is no problem with the line.
Message 10 of 10
The diagnostics bot is not infallible and is mistaken.
