Message 1 of 3
Here we go again
Hi.
back in November i was stuck in a banded profile, a mod @JohnC2 sorted it out and i got speeds as shown below
BT Hub 6A
Serial number:
+084319+NQ73768297
Firmware version:
SG4B1000E01E
Firmware updated:
15-Aug-2019
Board version:
1.0
Gui version:
1.105.0
DSL uptime:
9 Days, 13 Hours 48 Minutes 22 Seconds
Data rate:
6.96 Mbps / 41.71 Mbps
Maximum data rate:
7002 / 43019
Noise margin:
6.1 dB / 4.1 dB
Line attenuation:
24.6 dB
Signal attenuation:
0 dB / 24.6 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
now over the last 6-8 weeks speed has droped back and it appears im again on a stuck profile.
This is a list of your BT Smart Hub settings and current statistics.
Product name:
BT Hub 6A
Serial number:
+084319+NQ73768297
Firmware version:
SG4B1000E020
Firmware updated:
25-Mar-2020
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
2 Days, 15 Hours 2 Minutes 31 Seconds
Data rate:
5.96 Mbps / 30.40 Mbps
Maximum data rate:
5979 / 37319
Noise margin:
6 dB / 4.9 dB
Line attenuation:
37.9 dB
Signal attenuation:
23.5 dB / 37.9 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
quite line test is perfect.
help needed again please.
2 REPLIES 2
Message 2 of 3
Re: Here we go again
you are not stuck in a banded profile this time
have you tried using the test socket wit a filter to see if that improves your connection speed.  you line attenuation was 24.6db but now it has jumped to 37.9db suggesting a line problem
check this post
https://community.bt.com/t5/Home-setup-Wi-Fi-network/Bug-in-firmware-HH6-SG4B1000E020/m-p/2053308
Message 3 of 3
  • Thanks for quick response, line attenuation jumped to 37.9 after firmware update in March.
