Message 1 of 5
Connect landline to router
I have Panasonic KX-PRW120 home phones which I would like to connect to my Smarthub 2 to enable use of my smartphone to answer and make calls. The phone shows that it can be done but cannot detect any networks. All I get is a short stream of pips and then nothing.
Can anyone help?
4 REPLIES 4
Message 2 of 5
Re: Connect landline to router
do you have digital voice?
Message 3 of 5
Forgive my ignorance but what is meant by digital voice?
Message 4 of 5
Digital Voice is VOIP using the SH2 as a dect base station
as you obviously don't have it then your phone will not work connected to the SH2
Message 5 of 5
Thank you. I could not get any reasonable response from BT.
