Message 1 of 2
Connecting Wi-fi smart switch to smart hub 2 on 2.4ghz
I have been reading up on past posts regarding not being able to split the 2.4ghz and 5ghz on the smart hub 2. I am just wondering if anyone knows how to do this as I have a Wi-fi switch that only works on 2.4ghz. Even when I turn the 5ghz off it still doesn’t want to connect. Any advice is welcome.
1 REPLY 1
Message 2 of 2
Re: Connecting Wi-fi smart switch to smart hub 2 on 2.4ghz
Try going back into the wireless settings, turn the 5GHz off and then change the wireless mode to Mode 2 and try again.
If still no joy then try Mode 3.
Assuming you do get it connected, you should then be able to revert to mode 1 and turn the 5GHz back on
