Message 11 of 16
Re: Connecting a tablet to WiFi hotspot
if you are BT Broadband customer have you tried to connect to the BTWIFI network from your own hub first and see if that works
Message 12 of 16
Ensure you use the BT Broadband band choice
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 13 of 16
...........and not the default BT-Wifi
Message 14 of 16
I think I found the problem, I changed the option from  BT Wifi to BT Broadband & I connected to the hotspots... Thanks everyone...
Message 15 of 16
Glad "you" sorted it. Its an easy mistake to make by trying to login using the BT WiFi, which is the default login. Made the same mistake myself.
Message 16 of 16
