Message 1 of 12
Connection and reconnection frequency
Hi,
I've been looking through my router logs and have come across the following where the DSL line keeps dropping and reconnecting quite reguarly - many times per day.  Is this normal to do this?
02:23:01 02 May. DSL Link Up: Down Rate=123565kbps Up Rate=29145kbps; SNR Margin Down=15.0dB Up=4.8dB
02:21:23 02 May. DSL Link Down: duration was 179559 seconds
00:28:52 30 Apr. DSL Link Up: Down Rate=128376kbps Up Rate=29135kbps; SNR Margin Down=14.1dB Up=4.4dB
00:27:10 30 Apr. DSL Link Down: duration was 106176 seconds
18:57:42 28 Apr. DSL Link Up: Down Rate=118439kbps Up Rate=29123kbps; SNR Margin Down=15.2dB Up=4.1dB
01:08:55 28 Apr. DSL Link Up: Down Rate=121860kbps Up Rate=29135kbps; SNR Margin Down=15.1dB Up=4.4dB
01:07:14 28 Apr. DSL Link Down: duration was 252621 seconds
02:57:01 25 Apr. DSL Link Up: Down Rate=122144kbps Up Rate=29163kbps; SNR Margin Down=15.0dB Up=5.1dB
02:55:22 25 Apr. DSL Link Down: duration was 57298 seconds
11:00:33 24 Apr. DSL Link Up: Down Rate=100429kbps Up Rate=28700kbps; SNR Margin Down=16.8dB Up=4.2dB
10:58:53 24 Apr. DSL Link Down: duration was 5128 seconds
09:33:33 24 Apr. DSL Link Up: Down Rate=106087kbps Up Rate=27171kbps; SNR Margin Down=15.1dB Up=4.2dB
09:31:54 24 Apr. DSL Link Down: duration was 25167 seconds
02:32:35 24 Apr. DSL Link Up: Down Rate=120724kbps Up Rate=29135kbps; SNR Margin Down=15.0dB Up=4.3dB
02:30:58 24 Apr. DSL Link Down: duration was 20237 seconds
20:53:49 23 Apr. DSL Link Up: Down Rate=117565kbps Up Rate=29124kbps; SNR Margin Down=14.9dB Up=4.3dB
20:52:12 23 Apr. DSL Link Down: duration was 51455 seconds
06:34:45 23 Apr. DSL Link Up: Down Rate=104879kbps Up Rate=26915kbps; SNR Margin Down=16.3dB Up=4.4dB
06:33:09 23 Apr. DSL Link Down: duration was 14057 seconds
02:39:00 23 Apr. DSL Link Up: Down Rate=118167kbps Up Rate=29135kbps; SNR Margin Down=15.3dB Up=4.3dB
02:37:23 23 Apr. DSL Link Down: duration was 115828 seconds
18:27:03 21 Apr. DSL Link Up: Down Rate=119332kbps Up Rate=29104kbps; SNR Margin Down=15.0dB Up=3.9dB
18:25:24 21 Apr. DSL Link Down: duration was 414 seconds
18:18:38 21 Apr. DSL Link Up: Down Rate=112811kbps Up Rate=29133kbps; SNR Margin Down=15.2dB Up=3.4dB
18:16:02 21 Apr. DSL Link Down: duration was 71 seconds
18:14:59 21 Apr. DSL Link Up: Down Rate=108047kbps Up Rate=29113kbps; SNR Margin Down=14.7dB Up=3.0dB
18:13:21 21 Apr. DSL Link Down: duration was 2460 seconds
17:32:29 21 Apr. DSL Link Up: Down Rate=113947kbps Up Rate=29124kbps; SNR Margin Down=15.0dB Up=3.2dB
17:30:51 21 Apr. DSL Link Down: duration was 565 seconds
17:21:34 21 Apr. DSL Link Up: Down Rate=120733kbps Up Rate=29115kbps; SNR Margin Down=15.1dB Up=4.0dB
17:19:56 21 Apr. DSL Link Down: duration was 601844 seconds
18:09:20 14 Apr. DSL Link Up: Down Rate=121341kbps Up Rate=29135kbps; SNR Margin Down=15.1dB Up=4.5dB
00:47:55 13 Apr. DSL Link Up: Down Rate=125289kbps Up Rate=29155kbps; SNR Margin Down=15.1dB Up=5.1dB
00:46:19 13 Apr. DSL Link Down: duration was 245832 seconds
04:29:15 10 Apr. DSL Link Up: Down Rate=127295kbps Up Rate=29145kbps; SNR Margin Down=14.7dB Up=4.7dB
04:27:35 10 Apr. DSL Link Down: duration was 353417 seconds
02:17:26 06 Apr. DSL Link Up: Down Rate=126509kbps Up Rate=29145kbps; SNR Margin Down=14.6dB Up=5.2dB
02:15:49 06 Apr. DSL Link Down: duration was 175475 seconds
01:31:22 04 Apr. DSL Link Up: Down Rate=147880kbps Up Rate=29155kbps; SNR Margin Down=12.1dB Up=4.9dB
01:29:42 04 Apr. DSL Link Down: duration was 253033 seconds
03:12:37 01 Apr. DSL Link Up: Down Rate=156048kbps Up Rate=29124kbps; SNR Margin Down=11.0dB Up=4.6dB
03:10:58 01 Apr. DSL Link Down: duration was 33565 seconds
17:51:41 31 Mar. DSL Link Up: Down Rate=139117kbps Up Rate=29115kbps; SNR Margin Down=11.9dB Up=3.6dB
02:50:31 29 Mar. DSL Link Up: Down Rate=144452kbps Up Rate=29135kbps; SNR Margin Down=12.1dB Up=4.6dB
02:48:42 29 Mar. DSL Link Down: duration was 258365 seconds
02:02:45 26 Mar. DSL Link Up: Down Rate=139989kbps Up Rate=29145kbps; SNR Margin Down=13.1dB Up=4.9dB
02:01:06 26 Mar. DSL Link Down: duration was 219034 seconds
13:10:40 23 Mar. DSL Link Up: Down Rate=131785kbps Up Rate=29124kbps; SNR Margin Down=14.0dB Up=4.3dB
02:13:54 16 Mar. DSL Link Up: Down Rate=133532kbps Up Rate=29155kbps; SNR Margin Down=14.1dB Up=5.1dB
02:12:17 16 Mar. DSL Link Down: duration was 175327 seconds
01:30:18 14 Mar. DSL Link Up: Down Rate=142205kbps Up Rate=29155kbps; SNR Margin Down=13.1dB Up=5.0dB
01:28:40 14 Mar. DSL Link Down: duration was 174309 seconds
01:03:39 12 Mar. DSL Link Up: Down Rate=149871kbps Up Rate=29155kbps; SNR Margin Down=12.1dB Up=5.0dB
01:02:02 12 Mar. DSL Link Down: duration was 216656 seconds
12:51:14 09 Mar. DSL Link Up: Down Rate=157444kbps Up Rate=29124kbps; SNR Margin Down=11.1dB Up=4.1dB
02:49:33 09 Mar. DSL Link Up: Down Rate=158944kbps Up Rate=29155kbps; SNR Margin Down=11.2dB Up=5.0dB
02:47:55 09 Mar. DSL Link Down: duration was 174585 seconds
02:18:18 07 Mar. DSL Link Up: Down Rate=146544kbps Up Rate=29155kbps; SNR Margin Down=12.6dB Up=5.3dB
02:16:39 07 Mar. DSL Link Down: duration was 999727 seconds
12:34:40 23 Feb. DSL Link Up: Down Rate=158996kbps Up Rate=29124kbps; SNR Margin Down=9.0dB Up=3.8dB
00:58:03 19 Feb. DSL Link Up: Down Rate=159013kbps Up Rate=29165kbps; SNR Margin Down=9.9dB Up=5.2dB
00:56:22 19 Feb. DSL Link Down: duration was 823342 seconds
12:14:08 09 Feb. DSL Link Up: Down Rate=159093kbps Up Rate=29145kbps; SNR Margin Down=11.6dB Up=5.4dB
11:35:49 09 Feb. DSL Link Up: Down Rate=159023kbps Up Rate=29155kbps; SNR Margin Down=10.0dB Up=5.3dB
15:14:01 02 Feb. DSL Link Up: Down Rate=159023kbps Up Rate=29135kbps; SNR Margin Down=9.1dB Up=4.9dB
14:55:33 19 Jan. DSL Link Up: Down Rate=159141kbps Up Rate=29145kbps; SNR Margin Down=10.7dB Up=4.9dB
01:55:58 18 Jan. DSL Link Up: Down Rate=159013kbps Up Rate=29176kbps; SNR Margin Down=10.0dB Up=5.9dB
01:54:20 18 Jan. DSL Link Down: duration was 82528 seconds
02:59:00 17 Jan. DSL Link Up: Down Rate=159023kbps Up Rate=29165kbps; SNR Margin Down=10.1dB Up=5.9dB
02:57:16 17 Jan. DSL Link Down: duration was 438519 seconds
01:08:45 12 Jan. DSL Link Up: Down Rate=158973kbps Up Rate=29155kbps; SNR Margin Down=11.0dB Up=5.3dB
01:07:04 12 Jan. DSL Link Down: duration was 88622 seconds
00:30:10 11 Jan. DSL Link Up: Down Rate=159141kbps Up Rate=29165kbps; SNR Margin Down=11.1dB Up=5.8dB
00:28:32 11 Jan. DSL Link Down: duration was 171401 seconds
00:51:59 09 Jan. DSL Link Up: Down Rate=159023kbps Up Rate=29185kbps; SNR Margin Down=10.1dB Up=5.9dB
00:50:14 09 Jan. DSL Link Down: duration was 296299 seconds
14:32:03 05 Jan. DSL Link Up: Down Rate=159179kbps Up Rate=29145kbps; SNR Margin Down=10.4dB Up=5.1dB
12:10:29 22 Dec. DSL Link Up: Down Rate=159208kbps Up Rate=29155kbps; SNR Margin Down=10.1dB Up=5.1dB
11:55:02 15 Dec. DSL Link Up: Down Rate=159151kbps Up Rate=29145kbps; SNR Margin Down=10.1dB Up=5.0dB
11:37:38 01 Dec. DSL Link Up: Down Rate=159160kbps Up Rate=29135kbps; SNR Margin Down=10.1dB Up=4.6dB
11:21:16 17 Nov. DSL Link Up: Down Rate=159151kbps Up Rate=29104kbps; SNR Margin Down=10.0dB Up=4.3dB
11:04:45 03 Nov. DSL Link Up: Down Rate=159151kbps Up Rate=29145kbps; SNR Margin Down=9.6dB Up=5.0dB
11:06:30 02 Nov. DSL Link Up: Down Rate=159217kbps Up Rate=29095kbps; SNR Margin Down=9.3dB Up=3.9dB
11:02:41 02 Nov. DSL Link Down: duration was 160 seconds
11:00:09 02 Nov. DSL Link Up: Down Rate=158997kbps Up Rate=26180kbps; SNR Margin Down=2.9dB Up=3.1dB
10:43:33 02 Nov. DSL Link Down: duration was 127124 seconds
23:24:57 31 Oct. DSL Link Up: Down Rate=60000kbps Up Rate=16995kbps; SNR Margin Down=8.6dB Up=12.5dB
13:27:36 31 Oct. DSL Link Up: Down Rate=60000kbps Up Rate=16995kbps; SNR Margin Down=8.7dB Up=12.7dB
11 REPLIES 11
Message 2 of 12
Re: Connection and reconnection frequency
That is not normal and there is a problem with that many resets
Try quiet line test  dial 17070 option 2  should be silent and best with corded phone preferably from test socket
Message 3 of 12
Hi @dbr and welcome back.
It's been a while but it's great to see you again. Can you try the quiet line test mentioned by @imjolly and let us know how it goes?
Cheers
David
Message 4 of 12
Hello guys,
Thanks for your replies.
The first time I did the test, I got something about a entering a mobile number to receive SMS results from and did not do anything so I hung up.
The second time I tried it I got a quiet line apart from the periodic voice over telling me this was a quiet line test so I guess all is well there???
Message 5 of 12
As long as quiet line test was totally silent apart from announcement -  no hiss, crackle, etch
Have you tried using the test socket with a filter to see if that helps the hub stability?
Message 6 of 12
I have a Master Socket 5C which the router is plugged in to.
I believe this is filtered already?
Message 7 of 12
Yes, the master socket is prefiltered but the test socket isn't.
Message 8 of 12
Which master socket do you have
Message 9 of 12
Hi,
I have socket number 7.
Message 10 of 12
@dbr
That master socket is known to give problems, and is most likely the cause of your disconnections.
As mentioned https://community.bt.com/t5/Landline/2019-Master-Socket-kit-loose/m-p/1985566#M6775
You need to connect things up as shown below, and see if you still get disconnections. Leave it like that for a few days.
nte 5c testing from test socket.jpgNTE 5C Test socket check
